ramuk8avis
Newbie level 3
unsigned char sin_table[32]={0, 25, 50, 75, 99, 121, 143, 163, 181,
198, 212, 224, 234, 242, 247, 250, 250, 247, 242, 234, 224, 212, 198,
181, 163, 143, 121, 99, 75, 50, 25,0};
can anyone verify and tell why pulses are not getting from this.we are doing hardware inverter.I have dumped this code to pic 16f877a micro controller physically.so tell if any corrections in the above coding.or suggest any sine pwm coding.
thankingyou
unsigned int TBL_POINTER_NEW, TBL_POINTER_OLD, TBL_POINTER_SHIFT, SET_FREQ;
unsigned int TBL_temp;
unsigned char DUTY_CYCLE;
sbit MOSA at RD0_bit;
sbit MOSB at RD1_bit;
sbit MOSC at RD2_bit;
sbit MOSD at RD3_bit;
unsigned char FlagReg;
sbit Direction at FlagReg.B0;
//0 -> MOS A + D
//1 -> MOS B + C
void interrupt(){
if (TMR2IF_bit == 1){
TBL_POINTER_NEW = TBL_POINTER_OLD + SET_FREQ;
if (TBL_POINTER_NEW < TBL_POINTER_OLD){
//CCP1CON.P1M1 = ~CCP1CON.P1M1; //Reverse direction of full-bridge
if (Direction == 0){
MOSA = 0;
MOSD = 0;
MOSB = 1;
MOSC = 1;
Direction = 1;
else{
MOSB = 0;
MOSC = 0;
MOSA = 1;
MOSD = 1;
Direction = 0;
TBL_POINTER_SHIFT = TBL_POINTER_NEW >> 11;
DUTY_CYCLE = TBL_POINTER_SHIFT;
CCPR1L = sin_table[DUTY_CYCLE];
TBL_POINTER_OLD = TBL_POINTER_NEW;
TMR2IF_bit = 0;
void main() {
SET_FREQ = 410;
PORTD = 0;
TRISD = 0;
PR2 = 249; // 16kHz
CCPR1L = 0;
CCP1CON = 12; //PWM mode
TRISC = 0xFF;
TMR2IF_bit = 0;
T2CON = 0x04; //TMR2 on
while (TMR2IF_bit == 0);
TMR2IF_bit = 0; //Clear TMR2IF
PORTC = 0;
TRISC = 0;
TMR2IE_bit = 1;
GIE_bit = 1;
PEIE_bit = 1;
while (1);
thankingyou
