Split Attenuating Cap SAR ADC problem
elx
Newbie level 2
Hello
I have this problem about my SAR ADC...
I tried to simulate the SAR ADC by letting an input of 1.35 V at one terminal of the comparator (net vin). I unattach the sample and hold for now.
I expect that at first cycle when SAR logic output (D7~D0) is 1000 0000, the dac output (net98) must be equal to 0.9V but it gives me 0.587 V...
What I mean is i think the SAR logic at first will have an output of 1 at bit 7 which corresponds to an analog voltage of Vref/2 (vref=1.8V) which is 0.9V... but i notice it is 0.587.
I wonder what is the reason for this. Thanks in advance.
If the DAC is a charge redistribution type I'd be
looking at the switching and whether there is
excess charge injection or perhaps some make-
before-break bleed-off corrupting the charge
division.
You also need to look at the DAC's loading,
maybe it's a simple charge division problem.
Use some controlled sources to buffer between
stages and see.
I've got no way of knowing whether things are
otherwise logically correct.
