Help
Advanced Member level 2
Dear All,
Can we share 2 difference voltage source to Load with added a Inductor or Resistor in between 2 source?
The intention of connecting the Inductor/Resistor in between 2 source is either source will supply the voltage to Load A or Load B when either Regulator no output. Is it practical in this design?
I have experience, if Regulator-A supply the voltage without a Inductor/Resistor in series and no output supply from Regulator-B then the Regulator-B will get overheat.
Thank you.
Thank you.
