Spice model import to ADS
jayce3390
Full Member level 6
Full Member level 6
pspice model import
please, could you try to import the provided spice file in ADS and tell me if it works well?
I tried but the simulator told me some elements have been skipped.I don't understand.
Thanks in advance
creating a spice model in ads2008
please, just 1 min of your time, it's a quick process
import spice model to ads
Dear jayce 3390,
I tried your file in ADS2008 and it works for that you can see toy schematic cicruit in attached file.
As you know, it gives the schematic but i do not konw if it will works perfectly because i encountred a problem with NE351402_Spice, when i converted it in schematic cicruit then i tried to used it unfortunately it seems not work and i did not understand why......
good luck
N
    jayce3390
spice modelling ads
thank you nassim1, I think you got some Warnings during the translation, could you check eventually? because it seemed that the spice file contains switches and ADS is unable to understand.
pspice to ads
Hi colleague,
Your are right i have got it with warning. Below the warning message repeated here:
Netlist Translator (*) 331.200 May 6 2008
IFF translation log
Input format: PSpice
Input filename: E:\Mouloud\Works_07_08\ADS_Designs\mixers_prj\data\spice_test\el7457.lib
Output format: IFF file
Output filename: spice.iff
Special options:
Processing first line as comment.
Begin translation at Sun May 31 15:41:28 2009
Creating schematic with named connections.
Reading item definition file "C:\ADS2008U1/config\spctoiff.cfg"
WARNING: Skipping unrecognized element type: line #17, "spa1 17 16 1 5 swp".
WARNING: Skipping unrecognized element type: line #18, "spa2 17 9 5 1 swp1".
WARNING: Skipping unrecognized element type: line #26, "spa3 18 19 2 5 swp".
WARNING: Skipping unrecognized element type: line #28, "spa4 15 12 19 5 swn".
WARNING: Skipping unrecognized element type: line #29, "spa6 18 20 2 5 swp".
WARNING: Skipping unrecognized element type: line #32, "spa5 15 4 5 20 swp1".
WARNING: Skipping unsupported model type "vswitch", line #40.
WARNING: Skipping unsupported model type "vswitch", line #41.
WARNING: Skipping unsupported model type "vswitch", line #42.
Translation completed at Sun May 31 15:41:28 2009.
End of Spice Translation Log file, beginning of IFF Translation Log File
Beginning IFF import
Processing IFF file: spice.iff
Creating design el7457c
IFF import complete
Good luck
N
