SPI protocol software implementation
Fan174
Good evening to all
I am trying to flow chart to implement the bit banging method of spi interfacing. I have made it mine
I have attached flow chart. Please Help me to make it correct
  • SPI flow chart.pdf
not bad. But you have to take care about timing.
CLK=LOW and without delay CLK=HIGH may violate the specifications.
CS is never set HIGH.
Instead of bit bang mode:
I recommend to use a modern microcontroller with SPI periferal included.
Cheaper, faster, easier...
Hi Klaus
I have one query
Let's say I have PIC16F877A with inbuilt SPI and slave device (AT25HP256)
I have attached datasheet AT25HP256
How many slave devices (AT25HP256) we can connect at SPI Bus?
  • AT25HP256_AT25HP512_doc1113.pdf
As many as independent CS signals can be provided in your design.
and additionally this is independent whether you use inbuilt SPI or bit bang SPI.
