selva murugesan
friends,please tell me how to configure and using SPI in atmel?and also working of SPI
PORTB &= ~(1 << SPI_SS); //pull slave select low, start communication
SPI_Transmit(transmitting_BYTE);
receivingm_BYTE = SPI_Receive();
SPI_Finish();
PORTB |= (1 << SPI_SS); //pull slave select high, end communication
* FUNCTION: waits till SPI finish its operation
* INPUT:
* byte - byte value function should insert to register
* OUTPUT:
* None
void SPI_Finish(void) {
while(!(SPSR & (1<<SPIF)))
* FUNCTION: waits till SPI ready and writes byte to SPI data register
* INPUT:
* OUTPUT:
* None
void SPI_Transmit(uint8_t byte) {
SPDR = byte;
* FUNCTION: waits till SPI ready and reads byte from SPI data register
* INPUT:
* OUTPUT:
* None
char SPI_Receive() {
return SPDR;
* FUNCTION: sets up SPI settintgs to control LTC6802
* INPUT:
* None
* OUTPUT:
* None
void SPI_Init(void) {
DDRB = (1 << SPI_MOSI)|(1 << SPI_SCK)|(1 << SPI_SS); // Set MOSI SCK and SS as output
SPCR = ((0 << 7) //disable SPI interupts
|(1 << 6) //enable SPI
|(0 << 5) //DORD = 0 to set MSB is 1st to transfer
|(1 << 4) //setting device to Master mode
|(1 << 3) //settitng SPI mode
|(1 << 2) //^
|(0 << 1) //setting SPI clock to Fosc/16
|(1 << 0)); //^
SPSR = (0 << 0); //setting SPI clock x2 - disabled
PORTB |= (1 << SPI_SS); //Pull slave select high
