SpectreRF What this fields means
AdvaRes
At home
Hi all,
I'm confused while looking at these fields (red highlighted in figure below) of the spectre pnoise menue.
Could someone kindly explain what this fields mean.
type spectre -h pnoise in terminal
11 relharmnum=1 Harmonic to which relative frequency sweep should be
referenced.
14 refsideband Conversion gain associated with this sideband is used
when computing input-referred noise or noise figure.
20 maxsideband=7 Maximum sideband included when computing noise either
up-converted or down-converted to the output by the
periodic drive signal. It is ignored in HB small
signal when it's larger than the harms/maxharms of
large signal.
the number after `=` is the default value if you do not specify your own value
    AdvaRes
