spectre running error in ic 5033 at mandrack 9.2
jiannru
Newbie level 2
spectre status 512 cadence
Any body can help me.
Thanks a lot.
eoor message is :
spectre (ver. 5.0.33.120303 -- 03 Dec 2003).
Simulating `raw/inv' on xxxx at 10:13:48 PM, Thur May 6, 2004.
Error found by spectre during circuit read-in.
No circuit given.
*Error*
*Error*spectre terminated prematurely due to fatal error.
ERROR DURING Spectre EXECUTION, LOOK IN FILE spectre.out FOR THE ERROR.
Spectre returned status 512
I don't know what is it mean.
Anybody can help me.
Thanks.
spectre cc1 cadence
Dear All:
my spectre running error message(spectre.out) is:
cpp: unrecognized option `-$'
cpp: installation problem, cannot exec `cc1': No such file or directory
Command line:
/Cadence/tools.lnx86/spectre/bin/spectre +escchars +log \
../psf/spectre.out -env artist5.0.0 -format psfbin -raw ../psf \
-E -cols 80 +recover raw/inv
Loading /Cadence/tools.lnx86/spectre/lib/cmi/3.0/libinfineon_sh.so ...
Loading /Cadence/tools.lnx86/spectre/lib/cmi/3.0/libnortel_sh.so ...
Loading /Cadence/tools.lnx86/spectre/lib/cmi/3.0/libphilips_sh.so ...
Loading /Cadence/tools.lnx86/spectre/lib/cmi/3.0/libstmodels_sh.so ...
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `raw/inv' on xxxxx at 4:40:29 PM, Sat May 8, 2004.
No circuit given.
what mean is:
anaybody can help me?
Thanks...
spectre running problem
is there foundry module lib problem ?
I've found the solution. The error is because the c++ compiler is not installed at the initial installation.
Anyway, the developmnet package including the compiler can be installed by using "Install Package".
I have had the same problem. I have tried to simulate a design with IC 5033 version on madrake 9.2 and it fails.
The solution you give is to install the c++ compiler but I allready have one: gcc version 3.31 (Mandrake linux 9.2 3.3.1-2mdk).
Do I need to install another version of the c++ compiler?
Thanks in advace
