FlyingDutch
Advanced Member level 1
- Joined
- Dec 16, 2017
- Messages
- 457
- Helped
- 45
- Reputation
- 92
- Reaction score
- 55
- Trophy points
- 28
- Location
- Bydgoszcz - Poland
- Activity points
- 4,964
Spartan6 project interacting with DDR SDRAM (1 timing constraint not met)
Hello,
I am trying to implement project from this WWW page:
This is VGA framebuffer using DDR RAM (using the Spartan 6 MCB interface). This is my first project using DDR RAM, and I experienced difficulties.
I am using Mimas V2 Spartan 6 FPGA Development Board with DDR SDRAM. Here are links to producer site:
http://numato.com/product/mimas-v2-spartan-6-fpga-development-board-with-ddr-sdram
http://numato.com/docs/mimas-v2-spartan-6-fpga-development-board-with-ddr-sdram/
Here is packed with zip full project for Xilinx "ISE Webpack" (version 14.7) :
View attachment FrameBuffer01.zip
After synthesis and implementation I have one error - in "Timing constraints" there is one error "1 Failing constraint".
Here is ending part of "Post-PAR Static Timing Report":
I would like to ask if changing frequency to 50 MHz (from 100 MHz) of top entity would be proper solution?
Regards
There is one error in "top_level.ucf" file. Should be:
is
Sorry for that error.
Hello,
Derived Constraint Report
Derived Constraints for Inst_mem_wrapper/u_mem32/memc3_infrastructure_inst/sys_clk_ibufg
| | Period | Actual Period | Timing Errors | Paths Analyzed |
| Constraint | Requirement |-------------+-------------|-------------+-------------|-------------+-------------|
| | | Direct | Derivative | Direct | Derivative | Direct | Derivative |
|Inst_mem_wrapper/u_mem32/memc3_| 10.000ns| 3.334ns| 17.652ns| 0| 1| 0| 19616|
|infrastructure_inst/sys_clk_ibu| | | | | | | |
|fg | | | | | | | |
| Inst_mem_wrapper/u_mem32/memc3| 10.000ns| 0.952ns| 1.499ns| 0| 0| 0| 0|
| _infrastructure_inst/clk_2x_0 | | | | | | | |
| Inst_mem_wrapper/u_mem32/c3_s| 10.000ns| 1.499ns| N/A| 0| 0| 0| 0|
| ysclk_2x | | | | | | | |
| _infrastructure_inst/clk_2x_18| | | | | | | |
| 0 | | | | | | | |
| ysclk_2x_180 | | | | | | | |
| Inst_mem_wrapper/u_mem32/memc3| 13.333ns| 23.536ns| N/A| 1| 0| 19616| 0|
| _infrastructure_inst/mcb_drp_c| | | | | | | |
| lk_bufg_in | | | | | | | |
1 constraint not met.
Data Sheet report:
All values displayed in nanoseconds (ns)
Clock to Setup on destination clock clk_50
| Src:Rise| Src:Fall| Src:Rise| Src:Fall|
Source Clock |Dest:Rise|Dest:Rise|Dest:Fall|Dest:Fall|
clk_50 | 7.852| | | |
Timing summary:
Timing errors: 1 Score: 1275 (Setup/Max: 1275, Hold: 0)
Constraints cover 19616 paths, 0 nets, and 2128 connections
Design statistics:
Minimum period: 23.536ns{1} (Maximum frequency: 42.488MHz)
------------------------------------Footnotes-----------------------------------
1) The minimum period statistic assumes all single cycle delays.
Analysis completed Wed Aug 15 17:15:56 2018
Trace Settings:
Trace Settings
Peak Memory Usage: 202 MB
Regards
NET "mcb3_dram_ck" LOC = G3 | IOSTANDARD = DIFF_MOBILE_DDR;
NET "mcb3_dram_cke" LOC = H7 | IOSTANDARD = MOBILE_DDR;
is
NET "mcb3_dram_cke" LOC = H7 | IOSTANDARD = DIFF_MOBILE_DDR;
