ptjw
Junior Member level 3
hello all,
i mentioned a few weeks ago that i am doing a project which uses a Spartan 3A FPGA to read info from an SD card. this info tells the FPGA to route certain input signals to the output signals like if i want the signal from input 1 to be repeated at output 1 or 3 i can just change the data on the SD card and it will be done. (so much easier said than done..)
anyway i've run into a brick wall during the last phase of my code: during the assigning of output ports.
basically Xilinx ISE tells me that i have used up more than 100% of the device's resources...i have edited my code and by elimination, i have found the problem. my main code is really long and in a mess now but this is the primary culprit:
the arrayed variables on the left are the output ports while the variables on the right are the input ports. the variables with the '_BUF' are integers with a range of 1 to 40. when synthesizing this code i get this:
as you can see, this is totally not cool because this means my code can't be implemented into hardware (i'm guessing due to acute inefficiency from my inexperience in VHDL )
anyway, if i assign a random integer into the output port arrays, i use much lesser resources:
it's a drastic difference in amount of resources used, but i need to put the _BUF variables there because they hold the data retrieved from the SD card for routing the inputs to outputs. am i missing something here? i hope i'm doing something wrong and that there's a more efficient way of doing this...
i declared the _BUF variables like so:
FPGA_OUT(CLKLCD_BUF) <= CLKLCD;
FPGA_OUT(LCD_RESET_BUF) <= LCD_RESET;
FPGA_OUT(CS1_BUF) <= CS1;
FPGA_OUT(CS2_BUF) <= CS2;
FPGA_OUT(A0_BUF) <= A0;
FPGA_OUT(WR_BUF) <= WR;
FPGA_OUT(RD_SDA_BUF) <= RD_SDA;
FPGA_OUT(CLKIN_BUF) <= CLKIN;
FPGA_OUT(D0_BUF) <= D0;
FPGA_OUT(D1_BUF) <= D1;
FPGA_OUT(D2_BUF) <= D2;
FPGA_OUT(D3_BUF) <= D3;
Selected Device : 3s50atq144-4
Number of Slices: 894 out of 704 126% (*)
Number of Slice Flip Flops: 242 out of 1408 17%
Number of 4 input LUTs: 1613 out of 1408 114% (*)
Number of IOs: 67
Number of bonded IOBs: 63 out of 108 58%
Number of GCLKs: 1 out of 24 4%
WARNING:Xst:1336 - (*) More than 100% of Device resources are used
FPGA_OUT(1) <= CLKLCD;
FPGA_OUT(2) <= LCD_RESET;
FPGA_OUT(3) <= CS1;
FPGA_OUT(4) <= CS2;
FPGA_OUT(5) <= A0;
FPGA_OUT(6) <= WR;
FPGA_OUT(7) <= RD_SDA;
FPGA_OUT(8) <= CLKIN;
FPGA_OUT(9) <= D0;
FPGA_OUT(10) <= D1;
FPGA_OUT(11) <= D2;
FPGA_OUT(12) <= D3;
Number of Slices: 122 out of 704 17%
Number of Slice Flip Flops: 105 out of 1408 7%
Number of 4 input LUTs: 236 out of 1408 16%
Number of IOs: 67
Number of bonded IOBs: 35 out of 108 32%
variable CLKLCD_BUF : integer range 0 to 40 := 0;
variable LCD_RESET_BUF : integer range 0 to 40 := 0;
variable CS1_BUF : integer range 0 to 40 := 0;
variable CS2_BUF : integer range 0 to 40 := 0;
variable A0_BUF : integer range 0 to 40 := 0;
variable WR_BUF : integer range 0 to 40 := 0;
variable RD_SDA_BUF : integer range 0 to 40 := 0;
variable CLKIN_BUF : integer range 0 to 40 := 0;
variable D0_BUF : integer range 0 to 40 := 0;
variable D1_BUF : integer range 0 to 40 := 0;
variable D2_BUF : integer range 0 to 40 := 0;
variable D3_BUF : integer range 0 to 40 := 0;
variable D4_BUF : integer range 0 to 40 := 0;
variable D5_BUF : integer range 0 to 40 := 0;
variable D6_BUF : integer range 0 to 40 := 0;
variable D7_BUF : integer range 0 to 40 := 0;
