Sourcing ACS758 hall effect current sensor
stube40
Member level 3
Queensland, Australia
Any good suggestions where I can get hold of the Allegro ACS758 hall effect current sensor in low quantities with short lead times? I'm in Australia, but shipping costs aren't important.
I've already tried RS, Farnell and Digikey - all out of stock and long delays before new stock.
Try X-ON Electronic Services; they display 10-in-stock:
Rgds.
IanP
Rgds.
IanP
Unfortunately not quite the variant I was after - I need the ACS758LCB-100B-PFF-T
However, the bizarrest this is - the link you provided worked initially, now everytime I click it the X-ON site comes up with "0 search results". It's almost as if they updated the site to remove the ACS758 as I was using it. However, it's more likely that my browser is playing games - I will try a lucky re-boot and see how it goes.
Thanks for the X-ON site though - it's a gem by the looks of it.
hai,
presently am designing power monitoring system project in that am using ACS 756 IC. it gives sinusoidal output corresponding to the load .
when i trying to interface it with ADC of my controller, i try to catch the peak voltage of ADC for corresponding loads.
but the out put is not stable .could u suggest me some solution how measure the current from ACS 756?thanks for your support.
regards,
karthikeyan
