some questions about using hfss
sanders
Member level 3
i have two questions to ask:
(1) how to excite two ports at the same time in hfss, what can i do to realize it?
(2) how to set high-resistivity line or plane?assign it impedance boundary?
more quations:
(1) a paper mentioned: sheet resistence is around Rs=10κΩ/sq and each resistive line was designed to be at least 20 squares long. my question is how long a square is ? a square=(? )m.
(2) "the bias line conclude in dc pads of 150 and 400 pitch", so what is pitch?
(3) the loss tangent of high-resistivity Si?
That is all, any help will be appreciated!
HFSS-> Fields-> Edit Sources...
Yes,
more quations:
Square is arbitray unit, please refer to sheet resistence definition.
ρ=1/σ, for accurate simulation, you need the bulk conductivity versus frequency, which is quite difficult to get.
thank you ,asdfaaa.then i want to ask:
1 i want the bulk conductivity of high-resistivity Si in X-band (8-12GHz),can anybody tell me ,thank you!
2 "square " is often used, i want to know it represents which unit in general.
3 the last,"pitch" is what?
i will appreciated your help!
I dont have those data, maybe you can consult your vendor.
It is arbitray unit,
In a regular three-dimensional conductor, the resistance can be written as
R=ρ×L/A=ρ×L/Wt
where ρ is the resistivity, A is the cross-sectional area and L is the length. The cross-sectional area can be split into the width W and the sheet thickness t.
By grouping the resistivity with the thickness, the resistance can then be written as
R=(ρ/t)×(L/W)=Rs×(L/W)
Rs is then the sheet resistance. Because it is multiplied by a dimensionless quantity, the units are technically ohms. The term ohms/square is used because it gives the resistance in ohms of current passing from one side of a square region to the opposite side, regardless of the size of the square.
