powerelec
Junior Member level 2
I have a question about electronic transformer circuits that are used to drive halogen lamps. The questions are based on the attached document on the subject.
Regarding this document in Figure 1:
1) Is the self oscillating frequency constant? It seems that as the rectified AC input voltage changes, the voltage seen across the series inductance of (T1 + Primary_of_lamp_transformer) will increase. This will cause the current slope di/dt to be different every cycle, and the time required to saturate T1 will be different every cycle thus causing a varying frequency. But the author of the document seems to indicate that the frequency of the oscillation would be fixed at 35 KHz.
2) Any idea what typical values for the inductance of T1 and lamp transformer primary should be? Also what should be the ratio of saturation current values for the lamp tranformer primary and for T1?
3) With reference to the .png image I attached what will be the wave shapes of the voltages at node A and B and the currents through T1 and lamp during normal operation? Would greatly appreciate if someone could sketch these out.
I have trouble to visualize what the current shapes especially would look like.
Thanks for the help!
