Kaze105
Junior Member level 1
I have a motor that runs on 120VAC. It has 3 connections in total. 1 for 120VAC(hot) and the other two go to (neutral), but 1 connection rotates the motor clockwise, while the other counter clockwise.
The motor connection diagram - **broken link removed**
I want to control the direction of the motor using a 5V AC output from a uC (ATMEGA16).
Anyone have an idea of what kind of circuit should be used. My original circuit used a basic Relay that closes the connection when 5V DC is applied. The problem about this is that it can only connect to one of the 2 neutral connection of the motor and the relay uses DC voltage.
Sorry if this ends up a dumb question, thanks for any help.
