Some explanations about thyristor
ferrouga
Hi friends,
Its about MCC2614io1B
I need to understand what's exactly the meaning of the following points (please see attached file): Itrms, Itavm,Vrrm
What is the maximum of current, voltage for this thyristor?
Many thanks
  • MCC26THYRISTOR.pdf
IT(RMS)
ON−STATE RMS CURRENT
The maximum value of on−state rms current that can be
applied to the device through the two main terminals of a
Triac (or cathode and anode if an SCR) on a continuous
basis.
IT(AV)
AVERAGE ON−STATE CURRENT (SCR)
The maximum average on−state current the device may
safely conduct under stated conditions without incurring
damage.
VRRM
PEAK REPETITIVE REVERSE OFF−STATE
VOLTAGE
The maximum allowed value of repetitive reverse voltage
which may be applied and not switch the SCR or Triac on
or do damage to the thyristor.
Read more.............
Voltage ratings of high power semiconductors
Page 3. >> 1.1 Parameter definitions
https://search-ext.abb.com/library/...LanguageCode=en&DocumentPartID=&Action=Launch
Fundamental Characteristics of Thyristors
https://www.littelfuse.com/data/en/Application_Notes/AN1001.pdf
