Some Analog Monochrome TV Systems question?
muaythai2006
Newbie level 6
Newbie level 6
I need help wif some questions...It would be nice if u guy can help me out...=D
1)Which modulation technique is used for modulating a TV signal to a carrier frequency? What is the total bandwidth allocated for a TV channel? Illustrate with a figure the spectrum of a modulated TV channel.
2)Describe the difference between DSB-SC, SSB-SC, and VSB-SC. Illustrate with spectrum plots in the frequency domain.
3)With amplitude modulation (e.g. DSB), one can either suppress the carrier or transmit the carrier (leading to DSB-SC and DSB-C), discuss the difference in demodulation for DSB-SC and DSB-C. What are the major advantage and disadvantages of each?
4)Draw block diagrams for modulation and demodulation using VSB-SC. And explain briefly the function of each block in the diagrams.
