selva500
Junior Member level 3
lp3 package
Hi All.
Im working on a circuit that requires an LNA. The LNA im looking at is a 3 x 3 mm QUAD FLATPACK NO-LEAD (QFN) PLASTIC PACKAGE.
https://www.hittite.com/content/documents/data_sheet/hmc548lp3.pdf
I assume there wont be any legs on the component to solder it on to the PCB. How do I then attach the LNA to the PCB. Is there a way to solder it manually or must it be done by a device of some sort? I want to know as I may have to test out a couple of different circuits and its important that I can remove and reattach the LNA on these various circuits. Thanks.[/u]
Hi All.
