Soldering BGA? Producing a PCB around a Motorola 555
mms
Newbie level 2
Newbie level 2
hobby solder bga
I am willing to produce a PCB around a Motorola 555 microcontroller. But this is a BGA packaged chip and I can't solder it myself.
Does anybody know of a company that can solder BGAs for proto boards (ie. not at a high cost and in indicidual quantities) ?
PS: I'm in France, so please links only in European Union, thanks
Re: Soldering BGA ?
hai,
iam also need it
anybody have the facilite in india like in chennai or bangalore
bye
solder bga?
I think you need to look for metal mask stencil maker.
Or some one that can cut by laser those opening on a
0.15mm stainless steel metal plate. Once you have this
you need to buy a solder paste and appy this on the opening
by using metal squeege.
This process normally is use in SMT manufacturing.
you can do it on your own ((-:
have a look here h**p://wwwbode.cs.tum.edu/~acher/bga/index.html
Unfortunately it's in german, but you can see the ideas behind this approach.
i think it's not easy
If the pin count is low, I can do it with a heat gun. You must mark the PCB with an outline so that you can center the part. Touch a soldering iron to each PCB pad with a little solder and then remove it with solder wick so that each pad is tinned. Place the part on the board and then heat it with the heatgun. I use a wooden toothpick to gently push the part down to hold it in place when the solder reflows. It would be nice to have a paste stencil but sometimes you cannot afford one. This won't work if you have already removed the part and the balls are damaged.
