Soldering 20 awg solid wire to brass?
RobAinscough
Is it possible with standard 780 Watt soldering gun? I recall reading about using silver solder but that seems to be more for brass tubing.
Thoughts?
Cheers, Rob.
Done it often w/ 60/40 Pb/Sn, it wets fine as
long as you clean it bright first. Bond seems
as strong as solder-copper. For mechanical
strength, silver solder and (mini-) torch
would be superior.
Excellent, what do you usually clean the contact area with? Sandpaper, wire brush?
Cheers, Rob.
Fine grit sandpaper or steel wool.
I use silver solder occasionally to join narrow pieces, where strength is needed. Such as brass-plated eyeglass frames.
I remember Murphy's law: don't force it, use a bigger hammer.
If the wire is also brass, and the plate is relatively thin, you can use a regular solder and a regular soldering iron.
If the surfaces are not shining clean, use a sandpaper to prepare the surface. You can also use some more aggressive flux (ZnCl2 based).
For hard solder, you need a torch. The mechanical strength also depends on the contact area covered with solder.
Both leaded and unleaded solder should work fine.
