wutan1
Newbie level 1
Hi
I am looking for a very simple solution to measure if the difference voltage of 2 photo diodes is within a certain range. If both sensors see approx the same light, solar tracker should switch off to save battery.
Cant use a window comparator, as I need to be able to adjust voltage range the tracker should switch off.
Could subtract the voltages, then precision rectify....but thats too complicated.
Any simple solution with 1 or 2 op amps or comparators out there?
Thanks!
wutan
Thanks!
wutan
