Rajnaveen
Member level 2
HI friends ; i am facing a problem in 10 KW PCU ;in this system there is an inverter of 10 KW and solar mppt charger of 10kw panel; functionally system is ok . independantly charger works fine as well as inverter but when i run inverter +solar charger the ripple current at inductor of solar charger increases drastically up to 250A of 100Hz ; inverter discharging from battery is 100A at that time ,i am not getting why is it possible when battery is present why system tries to draw from solar side?
