Software delay calculation
Raveesh
I just use the for loop to generate some delay , If I want to generate the delay particular intervals of time , how to do that ..?
Ex: frequency I'm using is 8MHz and one instruction will be 4 cycles.
void delay(int del)
{ int i=0;
for(i=0;i<del;i++;)
What will be the delay generated by the above code if the del=0xFFFF;
regards
Ravee
The delay will be different for each mcu with different architecture (PIC, AVR, ARM etc) and can even differ with different compilers.
Alex
And remember that software delays are likely to 'run slow' if your system uses any interrupts or 'cycle stealing' technology (such as DMA in a consumer PC).
Can you tell, how to go with timer delay If I want a delays from 1ms to some second ..?
It would be very helpful to know the exact processor and compiler you are using. It appears you're using an 8MHz clock, but the other required details are missing from your posts.
I may be offtopic, but is not a good practice to use Delay to perform a wait function.
There is prefereable to use a timered interrupt flag instead.
This concept ( is not, but ) is somethink more close to multitask processing, sometimes called time slot.
I'm using MSP430 processor , and the compiler is IAR . I want to use the timer to generate the delay before calling few functions.
say I want to call some function after 100ms and some function after 50 ms , and all function will be called sequentially ..
regards
ravee
I, unfortunately, do not have an experience with the MSP430. However, I've uploaded a couple of appnotes, one of which deals with interrupt timers directly. The other is the C/C++ Manual for the MSP430, which has a interrupt timer example on page 116 and well as other places in the manual.
Here is a tutorial covering timers (Nov. 22) with several other links using the MSP430 and IAR Compiler:
MSP430 Tutorials
Hope this info helps you in your endeavor.
  • MSP430-slap113.pdf
  • MSP430-slau132e.pdf
regards
ravee
this fairly easy just go through the datasheet of your processor and study the timers and generate a timer interrupt for a common delay time e.g 1ms or 10 ms. then you can count the number of times the interrupt is been called and generate your required delay eg for a delay of 50 ms count 5 times if 10ms timer.
