[SOLVED] SMPS Power Inverter with TL494,1404
I strongly doubt that 4 parallel 23 AWG wires can handle 500 VA power... what current density for 23 AWG wire are you assuming KG300 ?
hy kg300,Hope you will be fine,,,,,i have made the pcb of 1500watt inverter and placed all components,but it's not working,,just led lights up and buzzer speaks,,TL494 is not giving output while input voltage is present at 8,11 and 12 pin of it,,,,please help me.
Give me the model number of this inverter and I will try to get the Circuit Diagram for you. This is a Chinese origin inverter. Q1 and Q2 are special package transistors. I have one complete circuit of another inverter from the same category. I will try to locate the file on my PC and will upload here, if I get. :)
hi there
can u help me designing an smps circuit ? the details are output : 7kv 1.5Amp
input : 115v 3phase , or 480v dc
frequency is optional ;)
what is TC1 in 1500 watt inverter???????
is Buzzer continues speak?
TC1 is 300 Ohm NTC Thermisto and mus be place on circuit. If you not have TC1, simply place 270 Ohm Resistor in TC1.
For easily Diagnose the fault, remove LM324 from circuit and run inverter and then check the Gate Voltages on both side MOSFETs. On DC side FETs there must be 4 to 5 volts. On AC side FETs there must be 5 to 6 volts.
Reactions: zertek
    zertek
yes,buzzer continusly speaking...by removing lm324 6volt on ac side while no change in dc side i.e, 0 volt
what should be the voltages on error amplifier pins?
kg300,,,,,,,another circuit only for tl494 that gives output????
Hi kg 300 i need 1000W and 1500W
botum of PCB and ,Schematic digramme if u hav please send to me
Hello everyone I have been a part of this forum for some time now and it is so hard to find a pure sine wave inverter circuit with transformer output base . can anyone send me a link thank u I would really appreciate.
1500 Watt Inverter using TL494, LM324, CD4013B, NE556.
you can use 75N75 on DC side and IRF740 on Output side. Use IE40H ferrite core with 3+3 turns on Primary side and 63 turns on secondary side.
KG300 you can file .brd
please
Hi any schmatic and pcb botum digramme?
Hey Everybody why did u guys stopped posting in here it's a very very helpful thread i got alot of missing puzzle form here please come on
Re: SMPS Power Inverter with TL494,1404--SG3525 And SG3524 1000W Inverter (12V)
SG3525 And SG3524 1000W Inverter (12V) With 15A Charger(90 to 265V) and Auto Shifting.
Low Bat Alarm
Fully Short Circuit Protection
Over Temperature Shutdown
Main Low Shift
No MCU (complete Analague)
Very Compact Design
No Load Consumption only 160mA
  • Drill Drawing For (TopLayer,Bot.pdf
  • paste.pdf
  • Silk.pdf
  • Top Assembly Drawing.pdf
  • Tracks.pdf
kg300, thank you for the post. Please give the winding details of the transformers. It will make it easy to complete the project.
KG300 You are amazing man Cool one fully Detailed and Files.... For the transformer if the turns are available it's better if not i can calculate it i just will wind my first smps transformer
by the way if i have an ETD39 core how many cores do i need to use it instead of the E55 and what is the best connection parallel primary and eries secondary or what? which is power efficient and less sensitive to winding error??
Sorry for long talk but i love to know more and more man
Dear All Experts Specially KG300 and PNJBTR
i want to make ur 12 volt smsp charger for 12 volt 220 ampere battery. now please send me the schematic and smps transformer winding procedure with all details of core etc. i m waiting for your reply.
1:
SMPS 20Amp 12Volt Battery Charger Based on Tl494.
12VDC 1200W Modify Sine Inverter with auto shifting.
Low Bat protection
OVL and TEMP Protection
Fuse based Reverse protection
  • Mask.pdf
  • Silk.pdf
  • Tracks.pdf
  • Mask.pdf
  • Mask-invert.pdf
  • Silk.pdf
  • Silk Mirror.pdf
  • Tracks.pdf
Here is the circuit. The oscillator based on SG3525 but u can use tl494, and lm339 with lm342. Add more power FET's to get more power.
---------- Post added at 20:06 ---------- Previous post was at 19:33 ----------
A very simple 500W inverter
Hi Master kg300,
What is the purpose of diodes (d10 and d11) across drain-source of upper mosfets?
