FalloutBe
Newbie level 5
Hello,
I tried to make a simple function generator using the MAX038 IC.
Schematic: https://www.circuitlab.com/circuit/mx397v/max038-function-generator
the OpAmp is a LT1364.
When the MAX038 is NOT connected yet, I'm getting + and - 15V, as expected.
For what should be + and - 5V, I'm getting +5V and -6V. When I connect a load to the output of the 7905, the voltage goes to -5V. I think this is not a problem.
The supply voltage is 29V
When I connect the MAX038 IC, the -+15V changes into +25V and -3.5V for some reason, and the OpAmp's temperature goes to smoking hot in about 10 seconds.
How is this possible?! how can the output of the OpAmp suddenly change, while it's inputs stay the same with those 10k resistors?
Kind regards
EDIT:
additional information:
The voltage across the 10k voltage divider at the + input of OpAmp A, stays nicely at +-15V while the output goes to +25V and -3.5V.
When overheating, the whole circuit draw 170mA of current.
Without the MAX038, when not overheating, the circuit draws 27mA.
Kind regards
EDIT:
