slot size intuition question in 5G NR
yefj
Hello,from the 5G NR manual shown bellow.
there is a diagram i have attache.
is there some intuitive explanation regarding why as the carrier spacing goes high then the slot time goes low.
how are these two connect together?
thanks.
https://www.sharetechnote.com/html/5G/5G_FrameStructure.html
In the literature is mentioned that slot length gets shorter as subcarrier spacing gets wider, due to the nature of OFDM.
Each carrier spacing have allocated a number of slots per subframe, when the subframe length is the same (1ms) for all carrier spacings.
So the slots get shorter and shorter with increase of carrier spacing, to fit in the subframe.
