chandra3789
Member level 1
frnds i am simulating MDAC stage in pipelined ADC........
The output waveform is shown below......
The DAC's functionality is working fine but when you have a close look at the output waveform you can see the negative and positive slopes of the output waveform.
The time of reaching the final value is divided as slewing time and settling time.......
if you observe the positive slewing is quite proper and there are no problems with it.....but the negative slope output is not slewing properly i.e., the slope is not a constant....because of this the negative output is a bit erroneous and the error is unacceptable......
so please tell me why the negative slewing is not proper ? what could be the reason for it?
