Skill code to add instance
yassin2705
Junior Member level 1
a skill code to add instance
I want a skill code to add an instance in a schematic sheet.
I tried the following code but it hasn't worked
procedure(
abc(component)
schHiCreateInst("tsmcN90" component "symbol" "I0" 1 1)
mouseAddPt()
0:0
then i call this function using:
abc("nch")
I am new to skill so i expect that there are much better ways to do that.
by the way, what does Hi stands for in the word schHiCreateInst??
Regards,
Yassin
layout instance add skill
Yassin,
Specify the error you are getting while using the above procedure. It should work and only will give warning for the instance name that you specified.
But in the schematic editor, you can get the same feature from the menu ADD->instance . Just assign one bindkey to this.
Let me know if you are not clear.
skill code for a schematic
sikadiya,
I am not having any errors, but the function is not executed as i expect. I am expecting that the component would be add at the specified location but this doesn't happen. What happens is that the "create symbol" dialog box is opened & the correct component is selected, but it is not added!
I want this piece of code to work because using for loops i can add many instances in different locations without opening the dialog box. i.e. to automate it.
Yassin
