Simulation Problem.
Engr. A.L.Y
Newbie
Hello Guys!
I'm having problem with my Proteus 8 Professional Software whenever I wanted to simulate a particular program I used to received the following messages:
-No power supply specified for net VCC in Power Rail Configuration;
-Simulation FAILDED due to netlist compiler error(s).
Please I need your assistance as I'm stuck.
--- Updated ---
Here is the attach of the error message I have been receiving.
this is a 3.5 MBytes picture that just tells what what could be written with a couple of bytes.
(a screenshot saved as -png usually is less than 100kBytes .. and every OS can do this)
The error says there is a problem with VCC configuration.
--> I´d say it´s a good idea to show your VCC configuration.
Klaus
an image of your circutry you are trying to simulate would be useful.
BR
You are either using some device with implicit power bus named VCC, or you added a power bus without defining its voltage.
At Schematic editor menu there is an option to do that:
