Richard29
Member level 1
Hi all,
I am trying to incorporate the Xilinx HWICAP controller into my design. The problem I face now is that I need someway
to simulate a FIFO that is generated with the FIFO Generator v6.1 as follows:
Of course when I just simulate my design this is a blackbox. But to see that I got everything right, I would need to be able to
simulate this core. Is there a simple way to do that? I assume I have to manually generate this core and then incorporate it in some way in my design. Some guidance what be great how best to proceed with this matter.
Many thanks!
COMPONENT fifo_generator_v6_1
GENERIC (
C_COMMON_CLOCK : integer := 0;
C_COUNT_TYPE : integer := 0;
PORT(
CLK : IN std_logic := '0';
BACKUP : IN std_logic := '0';
ATTRIBUTE box_type : STRING;
ATTRIBUTE box_type OF fifo_generator_v6_1 : COMPONENT IS "black_box";
ATTRIBUTE GENERATOR_DEFAULT : STRING;
ATTRIBUTE GENERATOR_DEFAULT OF fifo_generator_v6_1: COMPONENT IS
"generatecore com.xilinx.ip.fifo_generator_v6_1.fifo_generator_v6_1 -a map_qrvirtex4_to=virtex4 map_qvirtex4_to=virtex4";
Many thanks!
