anjyothiswaroop
- Joined
- Jan 24, 2011
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Tempe, Arizona
- Activity points
- 1,345
Hey,
I npticed a very unusual thing while simulating the gate level netlist to generate vcd file for power analysis. In the following example of decoder where I am taking the output at every clock edge, the VHDL source code is as following:
architecture behavior_decoder of decoder is
begin
process ( inp,clk,rst )
begin
if (clk'event and clk = '1') then
if (rst = '1') then
oup <= "00000000";
else
case ( inp ) is
when "000" =>
oup <= "00000001";
when "001" =>
oup <= "00000010";
when "010" =>
oup <= "00000100";
when "011" =>
oup <= "00001000";
when "100" =>
oup <= "00010000";
when "101" =>
oup <= "00100000";
when "110" =>
oup <= "01000000";
when "111" =>
oup <= "10000000";
when others =>
oup <= "ZZZZZZZZ";
end case;
end if;
end if;
end process;
I synthesised gatelevel netlist for this RTl with tsmc 45nm library tcbn45gsbwp_120a/tcbn45gsbwpwc.db
Everything seemed to be fine till this point. When I checked the timing report I realised the time period must be 0.05 ns.
Point Incr Path
clock (input port clock) (rise edge) 0.00 0.00
input external delay 0.00 0.00 f
inp[0] (in) 0.00 0.00 f
U24/ZN (NR4D1BWP) 0.05 0.05 r
oup_reg[0]/D (DFQD1BWP) 0.00 0.05 r
data arrival time 0.05
clock clock1 (rise edge) 0.08 0.08
clock network delay (ideal) 0.00 0.08
oup_reg[0]/CP (DFQD1BWP) 0.00 0.08 r
library setup time -0.03 0.05
data required time 0.05
data arrival time -0.05
slack (MET) 0.00
When I tried simulating in cadence NCsim with a test-bench with clock period less than 0.05ns everything seems to be working fine. I compiled the tcbn library in the work library and then the netlist. Even when I tried with a very small clk period it seems to be fine. Where am I going wrong? Something seems to be not correct.
begin
begin
if (rst = '1') then
oup <= "00000000";
else
case ( inp ) is
when "000" =>
oup <= "00000001";
when "001" =>
oup <= "00000010";
when "010" =>
oup <= "00000100";
when "011" =>
oup <= "00001000";
when "100" =>
oup <= "00010000";
when "101" =>
oup <= "00100000";
when "110" =>
oup <= "01000000";
when "111" =>
oup <= "10000000";
when others =>
oup <= "ZZZZZZZZ";
end case;
end if;
end if;
end process;
Point Incr Path
slack (MET) 0.00
