sajidmuhaimin
Newbie level 6
Hello,
I am trying to simulate two mutually coupled coils. I have created one coil in HFSS with 3d boxes, applying PEC material and adding a current source. The second coil is separated by a distance also made of PEC. Now if I run simulation in this set up, I can see MagJsurf to verify that current from one coil is being coupled to the other.
Now my questions are;
1) Can I introduce a finite conductivity part in the second box, to simulate the output resistance of the second coil?
2) If 1 is a yes, then how do I measure the power absorbed by the load resistance, as a function of frequency? and how do I measure the current through the second coil?
3) How do I measure the mutual coupling between the two coils?
I want to run a frequency sweep to find the power, resistance and other quantities.
Please help me.
![Ansoft HFSS - try1 - HFSSDesign1 - 3D Modeler - SOLVED - [try1 - HFSSDesign1 - M_2012-06-12_21-4.png Ansoft HFSS - try1 - HFSSDesign1 - 3D Modeler - SOLVED - [try1 - HFSSDesign1 - M_2012-06-12_21-4.png](https://www.edaboard.com/data/attachments/20/20753-d6663803bfd28367317ac7e48197cce1.jpg)
Please help me.
