Simplest GAL complier
techie
Advanced Member level 3
Pakistan
easyabel
I want to implement a BCD to 7-segment decoder (for LED display) in a GAL16V8. Can someone suggest a simple (& free) compiler and some reference code to do that easily
thanks
techie
abel gal
Hi, you want to hear some thing from Me :wink: :
I use an free version of easyABEL for DOS or Synario for Windows , they where shipped with an german Book "Schaltungstechnik mit GAL`s" .
Both are easy to use and in english language , if you are interested the whole CD is about 80~ Megs.
Hardcore
abel software gal
For simple 'stuff' , I use WinCupl which is offered (FREE) from Atmel.
Works just fine for me.. Cupl is very similar to Abel..
www.atmel.com
rfdes
wincupl seven segment decoder
Hardcore, can you post the easyABEL program only. It should not be more than a few KB.
abel descarga gal
You could try PALASM which you can find here.
It is somewhat old though.
easyabel.zip
I programmed a GAL16LV8D from L@ttice a couple of years ago. I used ispDesignExpert which was not free but you could get a 50 day evaluation from their site. I downloaded the files, installed it, requested a license to L@ttice (based in your hard disk S.N.) and that was it. If you need it again you could just request another one in another PC and so on. It's a small part so you don't need a lot of time to code it and the tool was very straight forward.
I can't find this tool in their site, it seems that it's been remaned or something to ispLeverStarter.
I programmed it in ABEL (I would go for VHDL today :) )
-Maestor
schaltungstechnik mit gals
Hi
Here is your BCD/7segment decoder in ABEL language (Abel Dos, Easy Abel dos, Synario.......)
Re: abel.zip
Hi I'm sorry to open such a fossil of a thread but would anyone still have this abel software, I am re-inventing some ancient hardware that depends on this software and I'll be darned if I can find a valid link anywhere.
Sometimes you can still find old resources with Ye Olde Wayback Machine.
  • abel_ref.pdf
  • ABEL Primmer.pdf
  • abel4.zip
Re: abel.zip
Thanks for that , I gave it a shot but it didn't work. Any other suggestions?
General suggestion: get creative. for downloads, zips etc usually the first try is a nogo. But usually I manage to find the stuff I need. Which doesn't help you, but it's more of a suggestion that with google + wayback machine + some thinking you can find a whole lot of old stuff floating out there...
