domble
Newbie level 3
Got an NRZ PCM data stream, need to recover a clock from it.
The PCM data is via a radio channel.
Using an integrate-and-dump filter to recover the actual data from the PCM, so the clock is used to time this.
Using a rectifier, ringing filter, and PLL works well, but...
The data rate may vary by about 10% (slowly, only temperature variations).
(The recovered clock is also used by the decoding PIC to adjust its own clock rate to match the data rate, recovered data is actually input via the UART). A ringing (LC) filter can't handle these large variations in clock rate.
So, we've tried different types of phase detectors which don't mind missing edges (i.e. PCM data). Now we can't get the PLL to lock over the full input frequency range using alexanders or hogge phase detector, unless it is also very sensitive to noise and jitter on the input data.
Any suggestions for loop filter types? Active integrating loop filter seems best (allows zero phase shift from hogge detector) but making it actually work is difficult.
2µs bit time, 74HC4046 VCO. PCM data from PIC, 'idle' periods of about 10 bit times max. Bit clock is continuous (i.e. doesn't change phase between tx bytes).
Someone point me towards a good resource?
dom.
dom.
