SIMCOM FLASH FILE UPDATE TOOL V1.10 PROBLEM
sheikhfayaz
Newbie level 2
simcom flash update tool
hello every body
i have a simcom sim300 module when i upload the total flash it uploads successfully but when i download the total flash to module it displays message AREA OUT OF BOUND please help whats problem.
the file version is : 10.0.8(XMST)3010SST34HFP2(2_16)
PLEASE HELP
THANKS IN ADVANCE
simcom firmware
Hi. I'm looking also to upgrade several SIM340. Where did you get the hardware tool and software to do that? A bunch of SIM340 don't response to AT command and I want to flash them again to see if they come to live again. Thanks in advance.
Dario
sim300 firmware
check out the attached document..hope it solves your problem
simcom flash
Hi
I have the version 1008B11SIM300C32_SST34HF3284 of simcom I obtain the 1008B13SIM300C32_SST34HF3284 firmware but I have problem with the Domain service, I can't use this function the B13 have problem with domain GPRS connection, they only connect by IP, you available the B14 version ?? this version fix the problem domain ,can you help me, but if you need the B13 version I can send to you.
Harold
quote="sheikhfayaz"]hello every body
PLEASE HELP
THANKS IN ADVANCE[/quote]
simcom downloader tool
hello
ok i will check out
send me file full readed
simcom firmware upgrade
Where can i download SIM300 firmware upload tool.
Please upload the latest simcom flash file update tool ! tnx in advance !
Re: simcom flash Upgrade Firmware
Hello, where can I download the firmware for the modem SIM300, which is not the last?
Oscar
Helo Every bdy, I need ur unjent help, I have Simcom flash update tool but i dont have the sim300 firmware (upload/Download) Files, soo please help me and please instruct how to update
Thanks In Adavnce
Re: simcom flash
Hi, my name is hernan
i need download firmware sim 300. ¿can you send me firmware 1008B13SIM300C32_SST34HF3284 please?
Hernancarlos@hotmail.com
thank you
regard
Hernan Loisi
haroldjulian said:
Hi
Harold
PLEASE HELP
THANKS IN ADVANCE
[/quote]
Re: simcom flash
while I do not have the exact file asked, I have the
1604B10SIM300M32_SST34HF3284.mot
This was given to me today, and I think it's the newest with solution for the TCP/IP problem I am facing.
I am very new o flashing SIM340, can anyone please guide where I should connect the serial port, is it on standard RX/TX port or RX_Debug/Tx_Debug port.
I am waiting for SIMCOM to reply me.
Re: simcom flash
this version is quad band?
thank you
regard.
Re: simcom flash
hi, i have SIM300 V7.03 modules and its revision number is: P1008B01SIM300M32_SST34HF_XMST_2010L_2_25T6, but i am not getting any network status, ring status indication in my board. is i have to update the firmware. if so, how can i update it?
thanking you
Re: simcom flash
Where, I can find the Firmware files for SIMCOM?
Re: simcom flash
if anyone is having firmware please send it to me. I have sim300 modules but they do not show network lights and they seem to be pre-programmed please tell me how can i do flash update. I tried with above tool and firmware posted in this forum it loads file into RAM but then update automatically stops.. please help me!! swapsan@gmail.com
---------- Post added at 09:13 ---------- Previous post was at 08:25 ----------
connect it to normal tx rx ports.
Hey every body
i have required 1604B12SIM300M32_SST34HF3284.mot file.
any one has this if u have please haelp me.....
awaiting for any ones replay.......
Re: simcom flash update tool v1.10
Dear,
I have upgrade SIM300 module it is successfully upgraded but the problem is old IMEI number is removed from the module and other IMEI number is their the IMEI number is not matched with module, and all modules which i upgraded same IMEI number is their I need to rewrite IMEI number do you have any solution of my problem I am waiting for your reply.
thanks in advance
Ms. Ritika
Email id - ritikashivhare246@gmail.com
Adjunto software para grabar el firmware al sim340Z. Solo les falta un archivo .mot de 8mb que no me deja subirlo.
Espero que les sirva.
If you got the following. Mot I'd appreciate that you send me.
1008B15SIM300M32_SST34HF3284.mot
1008B12SIM300M32_SPANSION.mot
thanks
  • SIMCOM FLASH UPDATE TOOL(DVersion) V1.30.exe
