Share one LCD between two projects
neazoi
Advanced Member level 6
Greece
Hi, I have an LC meter that uses a standard 2x16 LCD.
It uses the D4 (11), D5 (12), D6 (13), D7 (14), ENA (6) and RS (4) pins of the LCD. They are connected to the micro. The other pins are just to power the LCD.
I also have another project that uses the same pins D4, D5, D6, D7, ENA, RS.
I want to somehow share the same LCD between both circuits. How can this be done?
I am thinking of having both circuits powered up. The first will drive the LCB with power, contrast etc. and the D4, D5, D6, D7, ENA, RS pins will be switched from one project to the other using a multi-pole switch. There might be the need to switch off the power before I switch between the two circuits, I am not sure.
Will this work?
Any other ideas, to save up switches? For example series blocking diodes?
Would be best if you had one microcontroller dedicated to controlling the LCD. Then, your two projects can send display data to that.
Reactions: neazoi
    neazoi
I can't do that now. First because of lack of programming experience, second because of limited space (fitting the second project into the first project enclosure).
I have seen some examples with series diodes and pull down resistors on the net, also some recommend data switching ICs.
But because of LCD initialization issues (and others that may arrize), it may be more straight forward to use a 6-pole switch (3x2 poles connected together) to switch between these pins.
The first project will control the PSU and LEDs of the screen. The RW pin is connected to GND on both projects. Then the rest of the pins will be switched by this mylti-pole switch. The power to both circuit should be switched off before selecting one or the other project.
How do you find this solution, given the limitations in my case?
You could think about using analog switches, however it is not too clear your strategy to ensure that both systems will access the LCD not simultaneously. Perhaps you could use some signal form some of these systems and check how it berhaves in order to use it to control that switch.
Reactions: neazoi
    neazoi
Simultaneous use is not needed. Switcing off all circuits, then switch the LCD lines to the wanted project, then switch on all circuits. That is what I am thinking.
Hm... with three double throat ON-OFF-ON switches for each pair of circuits, switched together, I could even share the LCD on more than two projects, as long as only one "tripplet" switch is switched each time.
This would be fine so that only one toggle mechanical switch is needed. However, you will need two chips, with additional power. I am thinking that the circuit will become more complex than it can with a "tripplet" switch (three double pole double throat switches, switched together). I am thinking, is this complexity (and greater size) really needed?
I don´t like the idea.
In either case you need to connect the GNDs of both driving devices. I'd say continously, not switched to avoid ESD or other "out of specified range" voltages during switching.
Connected GNDs may cause problems. Even with the measurement.
Basicaly, if you have 'lack of programming experience' - than this project is just not for you yet. This solution is very durty.
