Serial to Parallel Converter
navinrk
Newbie level 3
Portugal
Hi all
Can anyone tell me how to implement Serial incoming bits into 4 bit parallel group? I mean, I generate (lets say) sequence of bits at random and want to convert the sequence into group of parallel 4-bits. I use binary generator (Bernouli), buffer it with 4 bits output, pass it to Demux of 4 bit. I would like to keep taking the set of 4-bits one by one and pass it further. How can I do? Please try to make me clear.
Hi all,
Communications_Engineer, can this really be done with matlab ?
Joannes has answered. Yes it can be done in Matlab. But in which language were you looking to implement it?
In matlab use can take a hint from this:
reshape(data,4,length(data)/4)
make sure length(data)/4 is an integer (by padding zeros if it is not)
Added after 1 minutes:
I hope I understood your question correctly
Added after 36 seconds:
(@ navinrk )
