serial data to parallel two bit data
quris_terris
Junior Member level 3
plz give me a circuit which receive a serial data and output 2 parallel bits at a time
ie if serial data is 11 10 10 00 then it output two parallel bits as first 00 then 10 then 10 then 11 . the output is 2 bits at a time
you can use a simple shift register and D flip-flops to latch the data every two bits.
use serial to paralel register IC (74ls163 for example)
and take the first paralel output pin 1 n 2
