serial communications with PIC microcontroller
E=MC2
Newbie level 6
im doing a project which requires a PIC microcontroller to communicate with the PC. basically the PIC has to give some data to the PC which should be displayed on a graph. i have some experience with Visual Basic so i am going to use it. i found the following links on another discussion on this board quite useful
http://www.rentron.com/sending_data.htm
http://www.rentron.com/receiving_data.htm
that solves the problem of sending and recieving the data but i want the data to be transferred to Excel which will make the graphs and the tables. how can i do that???
and one thing more. can someone tell me how to do serial communications using hyperterminal? and can i do the required task by using hyperterminal
Hello. The Visual Basic able to do this somewhat like database. Please go back to the any basic Visual Basic Book.
If you send data in a comma delimited format, then you can save the hyperterminal to a file and then import into excel, this is a crude way of doing it if you do not want to worry about VB
mita
    E=MC2
thanx for the replies
feitum9898 actually my knowledge of VB is limited to online tutorials so can you plz recommend a good VB book
and mitest i think ill stick with a solution involving VB because i want the whole thing to be an automated process. the user just has to send a command and all the tables and the graphs will be made automatically and saved to an Excel file. actually that might help in impressing my teachers :D
okay i have another question. i know that i can do the serial communications in C++ and Visual C++ but can i save the data to an excel file and display graphs and tables with it (using C++ or Visual C++)
