Transducer is something that converts one form of energy into another, like a temperature sensor particularly thermocouple outputs mv signal in proportion to temperature difference between two junctions, so this sensor is also a transducer. However a motor converts electrical energy into mechanical so this makes it a transducer but not a sensor.
hey thanks for giving reply to my thread guys..
In our discussion we have different answers like both are same and sensor can be a transducer but not vice versa...from this i have another question?
"A sensor is a device that measures a physical quantity and converts it into a signal which can be read by an observer or by an instrument...."
"A transducer is a device that converts one type of energy to another. "....these are the definition found in wiki...
so sensor can sense/measure and convert a quantity and transducer will only convert here my ques is can we say
sensor=transducer+signal conditioning circuit ?????????????????
(ie) sensing and then transduced is this right????????
u said both sensor and transducers are same.... but even in our discussion it is said they cannot be same...
can u make it little elaborate with some comparisons or examples :!::!:
a transducer converts an input to an output that can be exploited to accomplish the sensing mission. that is why i said transducer and sensor are same.
bi-metallic spring element can both detect temperature change, and may well be the entire sensor if a pointer is attached to the bi-metalic spring....... (so sensor is transducer)
An TV antenna is a transducer where electromegnetic energy is transformed and reproduced in to electrical energy. here my is strickly as a transducer but i can use the same antenna to check strenth of radio signal ....(transducer is sensor)
so i will say depends on your application or the way you are using a GADGET..........
