damayantha1991
Newbie level 2
hi guys this is my 1st post in this forum !!
I need send data between pc and pic so i made this schematic using proteus wrote the very simple ccs c code for pic 18f2550
and my schematic is goto https://obrazki.elektroda.pl/2276196000_1388233204.jpg or
and when i run the code the result is like this https://obrazki.elektroda.pl/6774018100_1388233383.jpg
or goto
so friend before this i used exsisr.c with little change
so proteus result for this is https://obrazki.elektroda.pl/5680434400_1388234039.jpg
or goto
SO in the both above cases i clicked on rx vir: terminal pressed keyboard buttons but they(the characters i presed) did not appear in output terminal
if i say clearly in first case (according to my little code) i pressed keys buttons but output is like in image ("start typing" then nothing..)
in second case the long code i keep pressing keys for 10s but output like the image i added ( bufferd data..bufferd data.. as in there)
And also i Used hyperterminal with virtual serial port software in second experiment but same results came as in image..
I'm using proteus 7.8
Think u clearly got my problem and show me how to fix this...
please help me guyssss!!
thankzz
or goto
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 #if defined(__PCM__) #include <16F877.h> #fuses HS,NOWDT,NOPROTECT,NOLVP #use delay(clock=20000000) #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) #elif defined(__PCH__) #include <18F2550.h> #fuses HS,NOWDT,NOPROTECT,NOLVP #use delay(clock=20000000) #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS,INVERT) #elif defined(__PCD__) #include <30F2010.h> #fuses HS, NOWDT, NOPROTECT #use delay(clock=20000000) #use rs232(baud=9600, UART1A) #endif #define BUFFER_SIZE 32 BYTE buffer[BUFFER_SIZE]; BYTE next_in = 0; BYTE next_out = 0; #int_rda void serial_isr() { int t; buffer[next_in]=getc(); t=next_in; next_in=(next_in+1) % BUFFER_SIZE; if(next_in==next_out) next_in=t; // Buffer full !! } #define bkbhit (next_in!=next_out) BYTE bgetc() { BYTE c; while(!bkbhit) ; c=buffer[next_out]; next_out=(next_out+1) % BUFFER_SIZE; return(c); } void main() { enable_interrupts(int_rda); #if defined(__PCD__) enable_interrupts(intr_global); #else enable_interrupts(global); #endif printf("\r\n\Running...\r\n"); // The program will delay for 10 seconds and then display // any data that came in during the 10 second delay do { delay_ms(10000); printf("\r\nBuffered data => "); while(bkbhit) putc( bgetc() ); } while (TRUE); }
or goto
thankzz
