ifforums
Newbie level 6
I extracted a sdf file from encounter (after place&route step). However, when I wanna feed it into the primetime (using this command: read_sdf circuit.sdf) to extract the delay it gives some errors/warning such as:
Information: Merging of parallel arcs is disabled by read_sdf. (SDF-040)
Warning: The SDF file is version 3.0. Current SDF-3.0
supported constructs are: REMOVAL, RECREM, RETAIN and CONDELSE. (SDF-026)
In timing spec
Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U4212/A2'. (PTE-014)
Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U6806/A2'. (PTE-014)
Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U6826/A1'. (PTE-014)
Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U6843/A'. (PTE-014)
Error: No net timing arc from pin 'U2214/ZN' to pin 'U1903/A2'. (PTE-014)
Note - message 'PTE-014' default limit (100) exceeded. Remainder will be suppressed.
Error: Error in SDF file /home/firouzi/benchmarks-synthesis/ITC/b15.sdf Line 17956: Syntax Error at or near token ''. (SDF-008)
Suppressed Messages Summary:
Id Severity Occurrences Suppressed
PTE-014 Error 897 797
Total 1 type of message is suppressed
Thank you for using pt_shell!
[victor@bcom]$ Information: Merging of parallel arcs is disabled by read_sdf. (SDF-040)
-bash: syntax error near unexpected token `('
[victor@bcom]$ Warning: The SDF file is version 3.0. Current SDF-3.0
-bash: Warning:: command not found
[victor@bcom]$ supported constructs are: REMOVAL, RECREM, RETAIN and CONDELSE. (SDF-026)
[victor@bcom]$ In timing spec
-bash: In: command not found
[victor@bcom]$ Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U4212/A2'. (PTE-014)
[victor@bcom]$ Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U6806/A2'. (PTE-014)
[victor@bcom]$ Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U6826/A1'. (PTE-014)
[victor@bcom]$ Error: No net timing arc from pin 'InstQueueRd_Addr_reg_2_/Q' to pin 'U6843/A'. (PTE-014)
Any idea about it?
Regards,
V.
In timing spec
Any idea about it?
Regards,
V.
