sdf back-annotation warning: conditional delay path
Robin_zhu
Newbie level 6
Hi
I met warnings on the COND path in sdf file can't be annotated to netlist.
all the COND path can't be annotated while others can be annotated.
ncelab: *W,SDFNEP: Failed Attempt to annotate to non-existent path (COND ((A===1)&&(C===1)) (IOPATH B Z)) of instance dbm_tb.u_dbmss.u_dut.SPARE_G_NAND3_1109 of module NAND3X8HXP </proj/DSP/workspace/rzhu/dbm_tb_env/chip/netlist/slow_125c_0p81v.cworst_125.sdf, line 127>
don't know why ... need help ..
Thanks and regards
Robin
paths on SDF should match your verilog model's specify block.
you can try generating SDF without conditional path in case your specify block does not have COND statements.
hi,
I also face the same problem described by Robin_zhu.
The condition statements are present in the cell library and SDF file. still the error pops up
BTW, im using VCS. I think the issue is similar
Any help is appreciated.
hi,
an update for this issue.
I was facing this issue while by doing the sdf annotation during simulation run time.
Changed this by precompiling the sdf and then ran the simulation and everything were woring fine :)
