Schematic from Netlist
suhas_shiv
Full Member level 2
Hi All,
Is it possible to get a schematic in Cadence by importing a netlist? Or is there any other software which does the same? Thanks.
Yes, you can use CDS Verilog-in, convert netlist to schematic.
your netlist must be gate level.
goodluck!
SpiceVision® PRO from Concept Engineering
http://www.concept.de/
"...SpiceVision PRO automatically creates easy-to-read circuit schematics from both pre- and post-layout transistor-level structures (Spice netlist descriptions). A schematic interface to the Cadence environment using SKILL enables mutual customers to easily process design data. For example, designers can now easily simulate a critical path at the transistor level. The path is created using SpiceVision PRO and is exported into the Cadence Virtuoso Schematic Editor environment...."
Spice In from Cadence
http://cdnusers.org/community/virtuoso/resources/ctp_CDNLive2005_1286vivek.pdf
But I do not know, what version includes this program. There can be it standalone.
