torbai
Member level 3
- Joined
- Nov 15, 2011
- Messages
- 67
- Helped
- 15
- Reputation
- 30
- Reaction score
- 13
- Trophy points
- 1,288
- Location
- Harbin,China
- Activity points
- 1,744
Hello
I recently am designing an S Band LNA using ATF-541M4, an Avago Technologies' p-HEMT.
But the stable factor shows that the amplifier is stable at any frequency except for somewhere around 16 GHz. This causes me a lot of problem. I've tried to put a series resistor at gate, but still can't kill the instability.
I've found that the reason why it is conditional stable is that the connection between the source of the FET and the ground is imperfect. The via hole really act as inductors, maybe resistors also, at 16 GHz. How to deal with that?
But I still remember that my goal is to design an S band LNA, should I really need to care about what is happening at 16 GHz? Can I ignore it? Or is there any possibility that what happens in simulation, the conditional stability at 16 GHz of cause, will never take place in real world?
