runtime plotting in matlab
nikhat_ahir
india
hi,
i want to plot data in matlab with data getting updated runtime, and so, need plot to get updated also.
for example,
for i=1:10
% get data
plot(data);
end
but, what i m getting is only one plot at end of the entire for loop instead of all intermediate plots.
what should i do to get my problem solved?
thanks in advance.
1. if you want to plot data on different figure each time, insert 'figure' statement in your code as --
for i=1:10
% get data
figure;
plot(data);
end
2. if you want to plot data in the same plot you can use hold on and plot data
figure;
hold on;
for i=1:10
% get data
plot(data);
end
hold off
You can use different color for plotting
ya, i have tried with given answers, but they are not working.
exact solution i got, and it is to use 'pause' with some argument showing very less amount of time, such as pause(0.1), after plotting data each time.
thanks, and regards,
nikhat ahir.
use "line"
use 'erasemode' to be 'xor'
no. its better to use pause instead of line or something else.
u just have to put one function, such as, pause(0.1), after each time u call to plot function.
nikhat ahir.
just use "line"
Added after 5 seconds:
just use "line"
The MATLAB command "drawnow" flushes pending graphics events.
for n=10:50
  plot(sin(n/100 * (0:99)));
  drawnow;
end
