majid_valentine
Junior Member level 3
rfm12b
hi all
can any body help me to initial rfm12 module with bascom or codvision please????
hi all
$regfile = "m88def.dat"
$hwstack = 40
$swstack = 40
$framesize = 40
$crystal = 8000000
$baud = 4800
Declare Sub Init_rfm12bp
Declare Sub Spi16(byval Dout As Word)
Declare Sub Send_buffer
Dim Dout As Word
Dim Dspi As Integer
Dim Dsdo As Integer
Dim Freq As Single
Dim Param As Word
Nsel Alias Portb.2
Config Nsel = Output
Sdi Alias Portb.3
Config Sdi = Output
Sdo Alias Pinb.4
Config Sdo = Input
Sck Alias Portb.5
Config Sck = Output
Nres Alias Portb.0
Config Nres = Output
Config Portc = Output
Config Portd.5 = Output
Dim Buffer As String * 10
Dim Shulp As String * 3
Dim Bhulp As Byte
Dim Bhulp2 As Byte
Dim Bhulp3 As Byte
Dim Bhulp4 As Byte
Dim Ihulp As Integer
Dim Whulp As Word
Wait 1
Nres = 1
Gosub Init_rfm12bp
Do
Buffer = "mulac"
Print Buffer
Call Send_buffer
Wait 10
Buffer = "ljudi"
Print Buffer
Call Send_buffer
Wait 10
Loop
Sub Spi16(dout As Word)
Nsel = 0
Dsdo = 0
For Ihulp = 1 To 16
Dspi = Dout And &H8000
If Dspi = 0 Then
Sdi = 0
Else
Sdi = 1
End If
Dout = Dout * 2
Dsdo = Dsdo * 2
If Sdo = 1 Then
Dsdo = Dsdo + 1
End If
Sck = 1
Nop : Nop
nop : nop
nop : nop
nop : nop
nop : nop
nop : nop
nop : nop
nop
Sck = 0
Print Sdi
Next Ihulp
Nsel = 1
Print "----------------------------------"
End Sub
Sub Init_rfm12bp
Nsel = 1
Sck = 0
Call Spi16(&H80d8)
Call Spi16(&H8209)
Call Spi16(&Ha640)
Call Spi16(&Hc647)
Call Spi16(&Hcc77)
Call Spi16(&H94a0)
Call Spi16(&Hc2ac)
Call Spi16(&Hca80)
Call Spi16(&Hca83)
Call Spi16(&Hc49b)
Call Spi16(&H9850)
Call Spi16(&He000)
Call Spi16(&Hc80e)
Call Spi16(&Hc000)
End Sub
Sub Send_buffer
Set Portd.5
Call Spi16(&H0000)
Waitus 5
Call Spi16(&H8228)
Waitus 5
Call Spi16(&H8238)
Waitus 5
Call Spi16(&Hb8aa)
Waitus 5
Call Spi16(&Hb8aa)
Waitus 5
Call Spi16(&Hb8aa)
Waitus 5
Call Spi16(&Hb82d)
Waitus 5
Call Spi16(&Hb8d4)
Bhulp3 = Len(buffer)
For Bhulp = 1 To Bhulp3
Shulp = Mid(buffer , Bhulp , 1)
Bhulp2 = Asc(shulp)
Param = &HB800 + Bhulp2
Call Spi16(param)
Print shulp
Waitus 5
Next Bhulp
Waitus 5
Call Spi16(&Hb8aa)
Waitus 5
Call Spi16(&Hb8aa)
Waitus 5
Call Spi16(&H8208)
Reset Portd.5
End Sub
$hwstack = 128
$swstack = 128
$framesize = 128
$crystal = 8000000
$baud = 4800
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcdmode = Port
Prr = 0
Dim Dout As Word
Dim Dspi As Word
Dim Dsdo As Word
Dim Param As Word
Config Portd.7 = Output
Config Portd.6 = Output
Nsel Alias Portb.2
Sdi Alias Portb.3
Config Sdi = Output
Sdo Alias Pinb.4
Config Sdo = Input
Sck Alias Portb.5
Config Sck = Output
Nres Alias Portb.0
Dim Nspi As Integer
Dim Wd As Word
Dim E As Byte
Dim F As Byte
Dim Rxt As Bit
Dim N As Byte
Locate 1 , 1
Lcd "Simple Rx"
Wait 2
Cls
Gosub Init_rfm12bp
On Int0 Rfmpart
Enable Int0
Config Int0 = Low Level
Enable Interrupts
Do
If Rxt = 1 Then
Rxt = 0
Locate 1 , 1
Lcd Buffer
End If
Loop
Rfmpart:
Buffer = ""
Locate 2 , 1
For N = 1 To 5
Call Spi16(&H0000)
Call Spi16(&Hb000)
Buffer = Buffer + Chr(dsdo)
Lcd Dsdo
Next N
Call Spi16(&Hca80)
Call Spi16(&Hca83)
Toggle Portd.7
Rxt = 1
Return
Sub Spi16(dout As Word) 'RFM12BP write routine
Nsel = 0
Dsdo = 0
For Nspi = 1 To 16 'clock 16 bits out
If Dspi = 0 Then
Sdi = 0 'shiftout a 0
Else
Sdi = 1 'shiftout a 1
End If
Print Sdi
Dout = Dout * 2
Dsdo = Dsdo * 2
If Sdo = 1 Then
Dsdo = Dsdo + 1
End If
Sck = 1
Nop : Nop : nop 'small wait
nop : nop : nop
nop : nop : nop
nop : nop : nop
nop : nop: nop
Sck = 0
Next Nspi
Nsel = 1
End Sub
Sub Init_rfm12bp 'Init the RFM12BP transceiver
Nsel = 1
Sck = 0
Call Spi16(&H80d8)
Call Spi16(&H82d9)
Call Spi16(&Ha640)
Call Spi16(&Hc647)
Call Spi16(&H94a0)
Call Spi16(&Hc2ac)
Call Spi16(&Hcc77)
Call Spi16(&Hca80)
Call Spi16(&Hca83)
Call Spi16(&Hc49b)
Call Spi16(&H9850)
Call Spi16(&Hced4)
Call Spi16(&He000)
Call Spi16(&Hc800)
Call Spi16(&Hc000)
End Sub
