52eoc
Newbie level 6
I have a project that used to monitor the lab with rfid door lock system. The tags data will be send through an ethernet connection in wireless connection in which there is two laboratory and one server(PC/host).There are 4 rfid reader entry points from first lab being place from the door of the entrance and the other one is exit door.The same with the second lab. My problem is can i used vb6 winsock application here for the application in which the can see the log of the student attendance and if not php will be my second choice.Then I will used a wifi router to establish connection from each lab.How can I know if the port is sending the data by using a tcp/ip module interface to a pic microcontroller circuit.Please give me some ideas on how to implement this one. because I have also database for application.
