burcum_sky
Newbie level 1
Hello Everyone;
I am new this job.
I can t find it what I want to do
I have four Rfid Cards ant i want to identificate them with Rfid Reader.
When Rfid card is read, the terminal writes ASCII Code like this;
i want to that;
when RFid reader read this code, it detect this code and uart write someone's name.
i did seperate cards with 60. bit but not enough.
can you help me this topic?
i wrote this part;
I working this code;
* Project name
RFiD (Displaying CRC check of RFid card via Usart)
* Copyright
(c) mikroElektronika, 2010.
* Revision History
20091220:
- initial release;
20101021:
- added active comments, sbit approach, code reorganized...
* Description
The code demonstrates using two external interrupts to read data sent
by EM4095 chip (clock - RDY/CLK; data - OUT).
Upon correct identification of the card, results are displayed via USART
along with the card specific number.
* Test configuration:
MCU: PIC18F4520
https://ww1.microchip.com/downloads/en/DeviceDoc/39631E.pdf
Dev.Board: EasyPIC6
https://www.mikroe.com/eng/products/view/297/easypic6-development-system/
Oscillator: HS-PLL, 32.0000 MHz
Ext. Modules: mE RFid Reader Board
ac:RFid_reader
https://www.mikroe.com/eng/products/view/185/rfid-reader-board/
SW: mikroC PRO for PIC
https://www.mikroe.com/eng/products/view/7/mikroc-pro-for-pic/
* NOTES:
- mE RFid Reader Board should be connected to PORTB
- Make sure you turn on the apropriate switches to enable USART communication (board specific)
- Upon correct CRC check program will send "CRC CHECK OK!" via USART
- Usage of P18 family of MCUs and clock setting >= 32 MHz is recommended when working with RFid Reader Board
I am new this job.
How can i identicate this code for anyone.11111111101001110110000000000010100110001100011111111010100111001
i want to that;
i wrote this part;
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 if(data_valid[60]==0) { UART1_Write(10); UART1_Write_Text("MİSAFİR"); UART1_Write(10); TRISD=0x00; LATD=0x0F; delay_ms(2000); LATD=0x00; } else { UART1_Write(10); UART1_Write_Text("PERSONEL"); UART1_Write(10); TRISA=0x00; LATA=0x0F; delay_ms(2000); LATA=0x00;
* Project name
* Copyright
* Revision History
20091220:
- initial release;
20101021:
* Description
MCU: PIC18F4520
Dev.Board: EasyPIC6
ac:RFid_reader
* NOTES:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 sbit OUT at RB0_bit; sbit RDY_CLK at RB1_bit; sbit SHD at RB2_bit; sbit MOD at RB3_bit; sbit OUT_Direction at TRISB0_bit; sbit RDY_CLK_Direction at TRISB1_bit; sbit SHD_Direction at TRISB2_bit; sbit MOD_Direction at TRISB3_bit; unsigned short sync_flag, // in the sync routine if this flag is set one_seq, // counts the number of 'logic one' in series data_in, // gets data bit depending on data_in_1st and data_in_2nd cnt, // interrupt counter cnt1, cnt2; // auxiliary counters unsigned short data_index; // marks position in data arrey char i; char _data[256]; char data_valid[64]; char bad_synch; // variable for detecting bad synchronization void Interrupt() { // This is external INT1 interrupt (for sync and sample) // it is enabled until we get 128 data bits if (INT1IF_bit && INT1IE_bit) { cnt++; // count interrupts on INT1 pin (RB1) INT1IF_bit = 0; } // This is external INT0 interrupt (for sync start) // - once we get falling edge on RB0 we are disabling INT0 interrupt else if (INT0IF_bit && INT0IE_bit) { cnt = 0; sync_flag = 1; INT0IF_bit = 0; INT0IE_bit = 0; INT1IF_bit = 0; INT1IE_bit = 1; } } char CRC_Check(char *bit_array) { char row_count, row_bit, column_count; char row_sum, column_sum; char row_check[5]; char column_check[11]; // row parity check: row_count = 9; // count rows while (row_count < 59) { column_count = 0; // count columns while (column_count < 5) { row_check[column_count] = bit_array[row_count+column_count]; column_count++; } row_bit = 0; // count row bits row_sum = 0; while (row_bit < 4) { row_sum = row_sum + row_check[row_bit]; row_bit++; } if (row_sum.B0 != row_check[4].B0) { return 0; } row_count = row_count + 5; } // end row parity check // column parity check column_count = 9; // count columns while (column_count < 13) { row_bit = 0; // count column bits row_count = 0; // count rows while (row_bit < 11) { column_check[row_bit] = bit_array[column_count+row_count]; row_bit++; row_count = row_count + 5; } row_bit = 0; // count column bits column_sum = 0; while (row_bit < 10) { column_sum = column_sum + column_check[row_bit]; row_bit++; } if (column_sum.B0 != column_check[10].B0) { return 0; } column_count++; } // end column parity check if (bit_array[63] == 1) { return 0; } return 1; } // main program void main() { ADCON1 = 0x0F; // AD converter off CMCON = 7; OUT_Direction = 1; RDY_CLK_Direction = 1; SHD_Direction = 0; MOD_Direction = 0; SHD = 0; MOD = 0; UART1_Init(19200); // Initialise USART communication Delay_ms(100); sync_flag = 0; // sync_flag is set when falling edge on RB0 is detected one_seq = 0; // counts the number of 'logic one' in series data_in = 0; // gets data bit data_index = 0; // marks position in data arrey cnt = 0; // interrupt counter cnt1 = 0; // auxiliary counter cnt2 = 0; // auxiliary counter // setup interrupts INTEDG0_bit = 0; // Interrupt on falling edge on RB0 INTEDG1_bit = 1; // Interrupt on rising edge on RB1 INT0IF_bit = 0; // Clear INT0IF INT1IF_bit = 0; // Clear INT1IF INT0IE_bit = 0; // turn OFF interrupt on INT0 INT1IE_bit = 0; // turn OFF interrupt on INT1 GIE_bit = 1; // enable GIE while (1) { bad_synch = 0; // set bad synchronization variable to zero cnt = 0; // reseting interrupt counter sync_flag = 0; // reseting sync flag INT1IF_bit = 0; INT1IE_bit = 0; // disable external interrupt on RB1 (for sync and sample) INT0IF_bit = 0; INT0IE_bit = 1; // enable external interrupt on RB0 (start sync procedure) while (sync_flag == 0) { // waiting for falling edge on RB0 asm nop } while (cnt != 16) { // waiting 16 clocks on RB1 (positioning for sampling) asm nop } cnt = 0; _data[0] = OUT & 1; for (data_index = 1; data_index != 0; data_index++) { // getting 128 bits of data from RB0 while (cnt != 32) { // getting bit from RB0 every 32 clocks on RB1 asm nop } cnt = 0; // reseting interrupt counter _data[data_index] = OUT & 1; // geting bit if(data_index & 1) if (!(_data[data_index] ^ _data[data_index-1])) { bad_synch = 1; break; //bad synchronisation } } INT1IE_bit = 0; // disable external interrupt on RB1 (for sync and sample) if (bad_synch) continue; // try again cnt1 = 0; one_seq = 0; for(cnt1 = 0; cnt1 <= 127; cnt1++) { // we are counting 'logic one' in the data array if (_data[cnt1 << 1] == 1) { one_seq++; } else { one_seq = 0; } if (one_seq == 9) { // if we get 9 'logic one' we break from the loop break; } } // (the position of the last 'logic one' is in the cnt1) if ((one_seq == 9) && (cnt1 < 73)) { // if we got 9 'logic one' before cnt1 position 73 // we write that data into data_valid array data_valid[0] = 1; // (it has to be before cnt1 position 73 in order data_valid[1] = 1; // to have all 64 bits available in data array) data_valid[2] = 1; data_valid[3] = 1; data_valid[4] = 1; data_valid[5] = 1; data_valid[6] = 1; data_valid[7] = 1; data_valid[8] = 1; for(cnt2 = 9; cnt2 <= 63; cnt2++) { // copying the rest of data from the data array into data_valid array cnt1++; data_valid[cnt2] = _data[cnt1 << 1]; } if (CRC_Check(data_valid) == 1) { // if data in data_valid array pass the CRC check UART1_Write_Text("CRC CHECK OK!"); // Writing of the CRC Check confirmation through USART communication UART1_Write(13); // Cariage return (view ASCII chart) UART1_Write(10); // Line Feed (view ASCII chart) for (i = 0; i <= 64; i++){ // This part of the code // dislays the number of the specific RfID CARD if (data_valid[i] == 0) { Uart1_Write('0'); } else { Uart1_Write('1'); // at the end of this for loop you will get a string of "0" and "1" } } // specific to a single RfID CARD UART1_Write(13); // Cariage return (view ASCII chart) UART1_Write(10); // Line Feed (view ASCII chart) Delay_ms(500); if(data_valid[60]==0) { UART1_Write(10); UART1_Write_Text("MİSAFİR"); UART1_Write(10); TRISD=0x00; LATD=0x0F; delay_ms(2000); LATD=0x00; } else { UART1_Write(10); UART1_Write_Text("PERSONEL"); UART1_Write(10); TRISA=0x00; LATA=0x0F; delay_ms(2000); LATA=0x00; } } } } }
