kmmaran
RF Experts,
I am using PD55015E (model) from ST Micro. Using MWO I have matched the output for Max Power from Load pull simulation, and matched with input with parallel RC for stability. Everything went well, good PAE and Max Power, S11 is close to 50ohm, but the power gain is not flat as you can see from the pic, and P1dB is bumpy (no pic attached).
Can anyone explain why the gain is not flat, I try both in ADS and MWO, and both having the same problem.
Thank you for the help.
Manimaran![Gain_Comp.JPG Gain_Comp.JPG](https://www.edaboard.com/data/attachments/57/57126-6ecfd462803baf2d31c80b078b5cbe56.jpg)
Manimaran
