Reverse CUrrent in sync buck charger system.
ljy4468
Full Member level 4
Full Member level 4
South Korea
Hi all I have a question about reverse current in sync buck charger.
Please refer to below articles and
https://www.ti.com/lit/ml/slyp089/slyp089.pdf
My question is in Fig. 22.
When a charger is started with battery connected, a huge negative current flows from the battery.
I don't understand how these huge current flows during startup,,,
Anyone can help me?
That current flows only if the buck converter is using a low-side FET as a synchronous rectifier to ground and not a diode. If the FET is on when the inductor current reverses direction then it will conduct large currents to ground from the battery. If a diode is used instead of a FET (at some loss in efficiency) then that path is blocked.
